2jz Soarer - New Timing belt kit and VVTI
Old 11-12-13, 04:46 PM
dfnmech
dfnmech's Avatar
Default 2jz Soarer - New Timing belt kit and VVTI
Just done new belt on car.
Car not running right.
Sounds retarded.
Everything lined up as far as we know.
Now checking oil pressure to see if its affecting VVTI
Sounds like timing is out.
Any One experienced this.
have had 3 mechanics look at it so far.
Cheers
Dom
Old 11-13-13, 06:51 AM
Vrank
Vrank's Avatar
Route the plug wires right? No codes?
Old 11-13-13, 11:55 AM
lexforlife
lexforlife's Avatar
common mistake made on setting timing on vvti .. make sure vvti cam gear is rotated fully to right before lining up vvti cam gear marks or it will jump timing .. rotate gear by hand then turn entire gear and set mark and install belt
Old 11-13-13, 08:11 PM
dfnmech
dfnmech's Avatar
According to the paperwork we have here it says ( AutoTech Encyclopedia )
#9 rotate engine clockwise until the TDC Timing marks are Aligned
" The second ( Left ) Crankshaft pully mark aligns with the O Mark on the lower timing cover."
" The Second ( Left ) Camshaft Sprockets marks Align "
#10 Rotate engine 60 Deg Anticlockwise until the 60 Deg BTDC Timing marks are Aligned
" The First ( Right ) crankshaft pulley mark Aligns with the O mark on the lower timing cover."
" The First ( Right ) Camshaft Sprocket Marks Align "
Do you mean Fully Rotated to the Right Facing the engine In Engine Bay from front of Car.
Do you mean the VVTI rotate to Right Clockwise from Front of Engine bay ?
Cheers
DOM
Old 11-13-13, 08:12 PM
dfnmech
dfnmech's Avatar
O2 Sensor Codes & Timing Code..
Cheers
DOM
Old 11-14-13, 03:17 PM
Ali SC3
Ali SC3's Avatar
he probably means the cam gear to the right when facing it, but I am not positive on that. That is probably your issue since its variably controlled it needs to be in a certain position when you put it back together.
which timing code, for vvti valve? or for the crank? something could have happened to your crank timing gear during the belt job.
Old 11-14-13, 08:41 PM
dfnmech
dfnmech's Avatar
As Far as I can see I have everything reinstalled correctly, I have undone and checked about 4 times but still sounds retarded, Like timing is out, Am I missing something, Is there something simple I am missing, Have pressurized cylinders, Done 2 rotations with crank and everything still lines up ok timing wise... have followed the 60 Deg BTDC , when sliding on VVTI does Inlet camshaft need to be at Top Dead center or at 60 deg before ? , Has been set at 60 deg as per the instructions We have, on 4th try have also tried TDC and rotated 2 revolutions and everything still lined up ok.... Any Help would be Appreciated... Thanks In Advance
SATXSC400
Performance
18
08-27-22 02:46 PM
dawson128
04-16-19 12:00 AM
SenecaRex
12-31-15 03:55 PM
donteatbug
Maintenance
10-26-15 05:41 PM
6SOARER
Performance
10-05-14 08:08 PM
Quick Reply: 2jz Soarer - New Timing belt kit and VVTI
