sc400 power steering resivor in sc with 1jz?
Old 12-06-13, 01:20 AM
Golden95SC
Golden95SC's Avatar
Default sc400 power steering resivor in sc with 1jz?
I picked one up for my swap but how exactly do you mount it? Do i need to make some brackets of some sort? Any one running a sc4 resivor with their 1j have pics of how you did it?
Thanks
Old 12-06-13, 03:59 AM
stockhatch
stockhatch's Avatar
I had an SC4 res in my 2jz swap, and mounted it to the shock tower and fuse box. I think most, if not all of the holes were already there. I just had to round up some hardware and then come up with a custom hose for the return.
Old 12-06-13, 09:46 AM
Ali SC3
Ali SC3's Avatar
find hole on chassis, find hole on reservoir, bend if necessary with some vice grips, bolt it in.
Old 12-06-13, 11:03 AM
Golden95SC
Golden95SC's Avatar
Perfect thank you
Old 01-13-14, 02:58 PM
Golden95SC
Golden95SC's Avatar
Hmm i was playing with the resivor today and trying to mount it. But i really dont want to drill into the fusebox, is there anyother way to mount it? The most obvious ways dont work because of the position of the feed and and return tubes, trying to use factory holes is tough to
But it looks like i might have to drill into the fusebox
Old 01-14-14, 09:43 AM
Ali SC3
Ali SC3's Avatar
there is a tab right behind the fusebox already by the tower. look at the picture above, its probably attached to that tab.
Old 01-21-14, 07:03 PM
Golden95SC
Golden95SC's Avatar
Thanks Ali, i figured out how to mount it, its not perfect but it actually holds up and its firm. I first drilled it into my fuse box and realized that it sat to high , so i bent the right tab upwards and put it in small hole behind the fuse box, so for future reference i guess this is one way to mount a sc400 power steering reservoir onto a sc3 with 1JZ.
1JZPWRD
12-24-11 07:02 PM
myke441990
SC- 1st Gen (1992-2000)
06-15-11 06:23 PM
suprus
SC400 / 300 Classifieds
11-28-10 03:34 PM
1985zcar
10-12-08 05:02 PM
RB26_S13
08-24-07 05:10 AM
Quick Reply: sc400 power steering resivor in sc with 1jz?
