sc400 sputters, please help
Old 12-06-13, 08:19 PM
jfriemel
jfriemel's Avatar
Default sc400 sputters, please help
hi all, im new here and to these types of cars, i recently bought my first lexus 2 weeks ago, it had a bad misfire that i knew of when i got it, pulled the wires to find one of them n pieces, i replaced them and the plugs and it still didnt fix it, it sputters rly bad on take off unless its cold, like rly cold, at about 30 mph i can punch it and itll sputter some more then it runs like a whole new car after it downshifts and reaches a higher rpm, anybody got some advice for me????
Old 12-06-13, 09:08 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Yes. Buy a Kia. Just kidding..never do that, you'll regret it for the rest of your life. Sounds like an ECU problem. Remove the ECU and have it rebuilt. Prior to that, open it up and check for leaking capacitors. Also a suspect would be the fuel pump ECU, you can have the 12v Mod done to it before spending 100 bucks on a rebuild. GL.
Old 12-07-13, 05:43 PM
jfriemel
jfriemel's Avatar
So the ecu huh, ok where is that? Lol is it passenger floorboard like my 240 was?
Old 12-07-13, 05:44 PM
jfriemel
jfriemel's Avatar
This is my car, I love it even though it doesn't run worth a crap lol
Old 12-07-13, 05:46 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Main engine ECU is on the passenger side floorboard. Pull up the carpeting, locate a plastic cover, romove the bolts, the rest is preschool.
Old 12-07-13, 05:51 PM
jfriemel
jfriemel's Avatar
Cool do u think a reset would do anything since I just changed the plug wires cuz one was n pieces?
Old 12-07-13, 05:54 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
You could have mentioned that prior to asking lol! Definitely reset the ECU. If the result comes out the same, you might have gotten the firing order incorrectly. Did you replace the plugs along with the wires? If not, you should.
Old 12-07-13, 05:56 PM
jfriemel
jfriemel's Avatar
Lol yea I changed both just didn't reset it lmao
Old 12-12-13, 01:03 PM
jfriemel
jfriemel's Avatar
Default update
ok i reset the comp n my sc400 and it still didnt fix it and now my check engine light is on...... on top of that my heater doesnt work, it blows warm as long as u dont turn the fan upverry high, it doesnt even blow hard enough to defrost the windsheild, any suggestions?
Old 12-12-13, 06:10 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Might have a rat nest in the blower mower. Where has this been parked? Outside?
On your problem, I would check the coils, and ignitor and the MAF.
Old 12-13-13, 03:13 PM
jfriemel
jfriemel's Avatar
I noticed the vacuum line on the intake is broke off, that may fix the sputtering but haven't been able to find a new one, but if thee was a best or something n the blower wouldn't that keep the a/c from working too? Cuz the a/c blows ice cold
Old 12-13-13, 03:14 PM
jfriemel
jfriemel's Avatar
Damn auto correct, I meant nest
dogman
11-21-13 08:50 AM
soarin87
12-17-12 09:07 PM
SCZack
SC- 1st Gen (1992-2000)
07-06-12 12:49 PM
o_man_76
07-24-09 02:33 PM
rlhsc400
07-22-08 06:38 PM
Quick Reply: sc400 sputters, please help
