300zx trans apadter
The same company that makes the 350z trans adapter for the 2jz also make one for the 300zx.
http://collinsadapters.com/index.php...-steel-72.html
The reason why im bringing this up because there is a massive abundance of the ka and sr trans where I am from and you can easily get one for 100 bucks while the r154 is 700 bucks+.
I have done a search, and I am just wondering if anyone has done the 300zx trans swap?
and I have also read that they hold just as much power as the r154 does.
Although the R154 may have questionably stronger gear set, they have their issues. Some people (including myself) are having issues with the rear seal. Even with a tighter w58 seal, it leaks from pressure inside the trans.
Neither is perfect. Although a CD009 or Getrag might just be as close as they get
actually I found one.
probably going to go this route over the r154 since the ar5 is a smoother transmission and its cheaper than the cd009 (since you have to spend 400 bucks on just the adapter itself and another 800 for the transmission)
shaodome
SC- 1st Gen (1992-2000)
05-04-10 07:50 PM
