Na-t injector question
According to the old write up on SF my virtual works intake flows well more than stock and required 13% more fuel. I'll be running an aristo tt ecu and found some 500cc injectors. Could I run those instead of the 440s and be about right? Math seems pretty good but don't know enough to know if there's a flaw in my logic.
Thoughts?
Thoughts?
500cc will be pretty close, the intake is not going to change that much where it matters and that is at idle and part throttle. I would guess that 13% number is on the top end. you can run 500's and it may run a little rich on part throttle but other than that should run pretty good, I say go for it. you may stumble while building boost if it goes too rich and then you will just need an afc to fix it.
don't go 600 unless you really need it, the larger you go the worse off it gets.
The 440's will work perfect and honestly the 500 is not a bad idea cause they will work right away and probably in boost also (the 600's will most likely give you issues in boost without an afc). its really a cointoss, the stock ecu can probably adjust for 500's fine by itself, you never know, I havent done it yet but it sounds plausible.
