rough idle but no power
it could also very well be your maf if you sprayed it down with maf cleaner. its like cryptonite to your maf.
they started adding warning labels to CRC maf cleaner on the back for older lexus and toyota vehicles with your kind of maf.
you have a 92, so yours should run without a maf connected even. try disconnecting it and see if it clears up the problem, if it runs smooth again its the maf, and you will have to try cleaning it in a different way with compressed air and letting it dry out completely with stuff that doesn't leave residues.
so i disconnected my mas and it didnt help, i also disconnected my ignition coils and it didnt help either. next step is to check my spark plug wiring. if that doesnt do it, it might be time to take it to a professional
well i checked all my wiring and it was all good, so then i thought my spark plugs could not be gapped right so i gapped them and no change. gonna take it to my mechanic buddy today
it definitely has to be an ignition problem because when i start it up it smells like raw fuel. so a couple of the cylinders probably arent getting spark. might just be bad wires
the idle dropped far enough that the car died on both of them. i havent heard anything back yet from my mechanic about it but i will update when i do
i heard back from my mechanic, he said it is a low intake vacuum. possibly could have sucked something up into the intake. he is gonna do a compression test on it on monday
compression on the drivers side was at 150, passenger side was at 50. come to find out the cam was off timing by four teeth.... thank god it didnt mess anything else up and i am gonna go pick it up today
