Z32 (300zx) Transmission on 2JZ
Like the title says, has anyone managed to put a Z32 (300zx) 5 Speed transmission on an SC300? I know there is an adapter plate that is required and the shifter sits a bit farther back but I can't find any info on this swap.
I'm only considering a Z32 transmission since it's much cheaper but more reliable than the W58.
Lexus owners seldom seem to incorporate different OEM parts, from what I can tell from this forum.
Z32 tranny is pretty stout, but if you're going to go through with making an adapter, driveshaft, trans mount and a custom clutch setup, you may as well spring for a Z33 tranny.
I don't think there is a huge difference in price between the Z33 and Z32 trannies. $550 vs 400.. but the Z33 is newer and chances are, has probably seen less abuse.
it would have to be a custom driveshaft. I believe you need a Nissan titan slip yoke.
collinsadapters.com
that website has the adapter kit, the clutch, and I believe they even sell a driveshaft for the cd009 transmission
collinsadapters.com
KahnBB6
Performance & Maintenance
45
01-20-16 08:04 AM
joel(PA)
40
01-12-10 01:46 AM
