soarer 1jz swapped sc300 cranking but no start
Hey guys so i just finished up the swap on onmy sc300, its a soarer 1jz automatic. Did all the matienace to it, new timing belt, water pump, front / rear main seals, plugs etc.
As far as the wiring goes its all hooked up but there are maby 4-5 wires from the body plugs harness i wasnt able to match up.
So today i went to crank it for the first and and it does crank and rotate but no start.
Im about to recheck my plugs, but like i said it cranks but no start.
Im thinking maby the ignitor is bad? Or what do you think can cause this issue? I do smell fuel so i assume its getting fuel, lastly is spark.
Lmk what you guys think
Edit: i just tested the car again, and with and without the ecu plugged in the car cranks over but no start
So tomorow ima recheck the wiring, check out ignitor as well and plugs, and im check the obvious things. sucks i really needed it to be running, if anyone can help me out plesse lmk
So i doubled checked maby i messed up on timing, but its all good, tdc and #1 cylinder up. I did pull the plugs and it is receiving fuel. Il double doublecheck the gap. Have em at 28, so i guess its not a fuel issue amd its a spark issue. Can somone enlighten me on what could be the issue? Can the cluster harness / body plug connectors prevent it from starting if a wire is off? Also i looked the crank positioning sensor, but i dont think it looks like anything is wrong with it
I recieved the engine from jdmenginedepot. There suppose to be big 2j/1j guys so i doubt the equipment i recieved is faulty
1JZ Single SC400
During this build or swap, did you do the fuel 12 volt mod? When you checked the timing, did you make sure all three points were aligned correctly, one on each cam, and one on the crank?
No i have not done the 12v mod. Is it sort of a mandatory thing? And yea the timing is dead on everything perfect. Now im thinking its spark issue. I pulled a plug out and i could smel fuel, also i undid the fuel to make sure and there was fuel going through it. i mean i dont get a little start or feel like the car wanting to start
Im gona try starting it without the body plugs plugged in, other than that i tightened down my spark plugs good and im sure my coils are in properly and connectors are in sequence.
So i finaly ixed up everything , new radiator and everythings hooked up, im stil in the situation. Cars just keeps cranking over. No spark whats so ever, can someone enlighten me on what i could try im kinda frustrated wit this lol. I neeed it to start badly
Ive seen people start 1js on palets idk how they can get it to run lol, anyone.know what wires.are a must for it.to start , maby thats my fault
100% guaranteed its your wiring, or wiring related. Are the grounds to the intake tight? How is it even turning over with the body plugs not plugged in? Does your check engine light work?
You shouldn't try to wire these things if you don't understand how they work. And I know you don't understand how they work because you attempted to start the vehicle with the body plugs unplugged. That means you fail to realize how the system gets its power.
No the car will not crank over without the plugs they are mandatory,(i learned that quickly) lol, its more than likely that the wiring is off but its strange that everything is up to par with the wiring other than not sparking which could a multitude of things. And yes i agree i dont have the slightest clue on what im doin with the wiring, i have minimal experience in that department. But it seems to me with the wiring that i did , it should be enough to get the car going. I could be dearly mistaken though.
Im going to double check my grounds, and im going to have the ignitor tested as ive read that these things tend to go out.
Thanks for the input guys
As far a the check engine light i belive off (so it must not be.working since it should be on when the power is on) but wont know for sure suretil the car is running.
The only grounds that i know i connected was the tranny ground and the one of the back of the motor. Am i missing some? Ima see what i can find out
