2JZGTE Wiring Harness Made Easy
#167
I actually keep the 3-connector (Supra/Lexus) and 4-connector (Tundra/GX470) wired together to support any alternator. Then, I can revert back to the old alternator if I'm in a pinch. The Tundra alternator outputs much more current at lower RPMs.
The p/n# for the 4-pin connector you will need is 90980-11964.
The supra 3 pin connector the pins are as follows:
1-L-terminal for charging light
2-IG-terminal for ignition power
3-S-terminal for Alternator sense
The Tundra 4 pin connector the pins are as follows:
1-S-terminal
2-IG-terminal
4-L-terminal
Thanks,
-scott
1-S-terminal
2-IG-terminal
4-L-terminal
Thanks,
-scott
#168
Attachment 425988
For SC300 & SC400
IK1
Pin 8 of IK1 goes to Pin 1 of Short Connector and to Pin 4 of Igniter (TAC)
Pin 9 of IK1 goes to Pin 1 of Water Temp Gauge Sensor
For SC300
IK2
Pin 24 of IK2 goes to Ground on Front Intake Manifold
Short Connector (6 pins)
Pin 1 of Short Connector goes to Pin 8 of IK1 Connector
Pin 2 of Short Connector goes to Pin 20 of IK1
Pin 3 of Short Connector goes to Pin 3 of IJ1
Pin 4 of Short Connector goes to Pin 3 of EB2
Pin 5 of Short Connector goes to Pin 7 of IJ1
For SC400
IK2
Pin 24 of IK2 goes to Ground of Rear Side of Cylinder Head
Short Connector (3 pins)
Pin 3 of Short Connector goes to Pin 9 of IK1
Attachment 425989
For SC300 & SC400
IJ1
Pin 2 of IJ1 goes to Pin 2 of II1 & Pin 2 of VSV (Water Valve) Connector
EB1
Pin 1 of EB1 goes to Pin 4 of the AC Connector
Pin 2 of EB1 goes to Pin 23 of the 40 Pin Connector
Attachment 425990
For SC300 & SC400
II1
Pin 1 of II1 goes to Pin 7 of the EB1 Connector & to Pin 1 of the AC Connector
Pin 2 of II1 goes to Pin 2 of the IJ1 Connector & Pin 2 of the VSV (Water Valve) Connector
Pin 4 of II1 goes to Pin 2 of the AC Connector
Pin 5 of II1 goes to Pin 34 of the 40 Pin Connector
Pin 7 of II1 goes to Pin 1 of the VSV (Water Valve) Connector
IK1
Pin 10 of IK1 goes to Pin 11 of the Data Link Connector
EB1
Pin 7 of EB1 goes to Pin 1 of the II1 Connector & to Pin 1 of the AC Connector
For SC300 & SC400
IK1
For SC300
IK2
For SC400
IK2
Attachment 425989
For SC300 & SC400
IJ1
EB1
Attachment 425990
For SC300 & SC400
II1
IK1
EB1
Hey Gerbb, thanks for this post, it helped me figure out why my ambient temp sensor wasn't reading. The guy who made my harness did not pin #7 on EB1 at the fuse box so i spliced it into Pin 1 of the AC Connector and everything works flawlessly now!!
#169
Gerry always coming in clutch!!
YoshiFD3S
SC400 / 300 Classifieds
01-06-12 05:22 PM
