Best ECU to use with JDM Rear Sump 2JZGTE Non-VVTI) moto that didn't come with a ECU?
I posted this on Supra Forums but maybe Club Lexus would be more knowledgeable about swaps
The motor: 1993 - 1996 JDM Rear sump 2JZGTE M/T from a Supra 6 w/ a V160. Complete harness
The car: 1994 Supra N/A w/ V160 6 speed
The problem: No ECU
I've been searching all over the internet for the following ECUs:
89661-14500 (93-93.5 Turbo, Manual)
89661-14501 (93.5-96 Turbo, Manual)
Car is a Manual w/ a V160
Those are the two proper ECUs that I *should* be running. However, they're basically impossible to find. So anyone have any suggestions on the best route going forward? Aristo ECU? USDM TT ECU? Not sure at this point....
The problem: No ECU
Are those part numbers for Jdm supra map-based ecu's? I'm sure if your patient enough you'll find one. You can use a jzs147 aristo ecu too. Or why not try a Mines ecu with boost and speed cut eliminated?
I am for now because going single turbo w/ mods isn't my goal right. At best, I'll go TTC. The only mod is an exhaust atm. I'm probably not even going to get an electronic boost controller.
Ali SC3
SC400 / 300 Classifieds
05-19-14 01:41 PM
