broken parts on 2.5TT - need PN
Hi,
I already have a thread about my car, but I start a new one for some specific issues I have with the engine.
So I've started working on a 2.5TT engine after being able to start it last week.
While having a deeper look at it, I found:
- 1 broken sensor that I was unable to identify for sure. It was connected to a 2-pin green connector close to the serpentine belt. I think it's an oil sensor, but if anyone can confirm it, give it's part number and explain if there are some difficulties in replacing it, I would be really grateful.
![broken parts on 2.5TT - need PN-broken-connector.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/317584d1461367695t-broken-parts-on-2-5tt-need-pn-broken-connector.jpg)
![broken parts on 2.5TT - need PN-broken-connector-green.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/317585d1461367695t-broken-parts-on-2-5tt-need-pn-broken-connector-green.jpg)
- 1 broken hose, that is used for air intake of the engine (for what I can understand). Is it a specific one that I need to buy at a Toyota dealer or can I find in a car-shop like Autobahn, Repco or else?
![broken parts on 2.5TT - need PN-broken-hose.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/317586d1461367695t-broken-parts-on-2-5tt-need-pn-broken-hose.jpg)
Thanks,
Thanks,
Hi mate,
The hose part number is 12263-88401. Cost is about $13, but I doubt Toyota AUstralia stock it and will need to special order it from Japan, which would push the price up. I would suggest going to an Automotive store and get a hose in the same size.
I cant tell what the sensor is from those pictures, could you zoom out. If I was to take a guess I would say it is the water temp sensor.
![broken parts on 2.5TT - need PN-broken-connector-green-1.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/317659d1461367695t-broken-parts-on-2-5tt-need-pn-broken-connector-green-1.jpg)
![broken parts on 2.5TT - need PN-broken-connector-green-2.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/317658d1461367695t-broken-parts-on-2-5tt-need-pn-broken-connector-green-2.jpg)
Ok, some news: in fact, I've made an error while translating the warning message on the dashboard.
I've confused
- warning for brake system - with this one
- warning for the engine system.
I was finding information on internet about brake, sensor, fluid... when I've realized the confusion !
So when I had a look for this message, I've found the way to have the error code on the dashboard with the DIAG plug. Therefore, I have EFI NG with a code 22 and ECT OK.
EFI 22 is an Engine Coolant Temperature Sensor Signal, So I believe CZAR07 was right about the water temp sensor.
I will have a look tomorrow in an automotive store for a new one, replace it and try.
Maybe that will also fix the fact that the idle when the engine is cold is difficult and looks like the engine will stall. At first, I thought it came from old fuel in the car that was no more "powerful" enough but maybe not the only reason.
I've confused
![broken parts on 2.5TT - need PN-74536.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/317709d1461367695t-broken-parts-on-2-5tt-need-pn-74536.jpg)
![Name: 74543.jpg
Size: 2.3 KB](https://www.clublexus.com/forums/attachments/performance-and-maintenance/317710d1393752846-broken-parts-on-2-5tt-need-pn-74543.jpg)
For the sensor, when I've tried to remove it, lot of coolant have bleed also.
Do I need to flush the coolant before removing and replacing it ? Or maybe just to put the front or the rear of the car higher to prevent this ?
and for the hose, when I removed it, inside was really full of oil (I think it's oil). Is it normal or does it shows a problem with the engine ?
You will lose some coolant from there, but not too much as that is the coolant return to the radiator..you will probably need to top off with more coolant..
Yeah oil in the hose is fine.
ok thanks for the reply. I'll change the hose within a few days.
For my information, the hose seems to be an air intake for the engine. If so, why so much oil inside?
I've gone to Supercheapauto yesterday, they don't have the sensor and they've quoted it $49.
Is that a good price or not ?
its a crank case breather hose. when you boost alot the extra pressure goes out of the engine into that pipe and into the intake. usually it is an oil mist or filled with oil, how bad depends on how healthy the motor is or isn't.
that is what people use a catch can but on a stock gte its fine just replace the hose.
Weapon F
IS F (2008-2014)
15
11-24-15 11:22 AM
