High or low impendance injectors?
Help needed to make a decision in purchasing injectors.
I am doin a NA-T build with my 2jz-ge build. I want to use 100cc injectors but I don't know the difference between the high and low impendance injectors. Which one is better for my na-t build and what is the difference between the 2...?
Your in the wrong section but..... for a GE motor set you will need the high imp top feed injectors at 14ohms making them High imp. Low imp injectors are for the GTE motor set which are side feed injectors at 3-4ohms making them Low imp.
Use the search button always works... cheers!
LEXO400sc
Performance & Maintenance
11-20-03 09:20 PM
