Sc400 won't reverse
Old 03-05-14, 07:59 PM
slvrboolet
slvrboolet's Avatar
Default Sc400 won't reverse
Buddy of mine has a92 sc400 the forward gears work fine but it won't go into reverse. Is this something simple or is it toast? He wants to fix it for his daughter but if it requires $2k for repaird hell just dump it... Any ideas?
Old 03-05-14, 08:15 PM
Ali SC3
Ali SC3's Avatar
sounds like one of the solenoids responsible for reverse has gone out. you might have to take them off to see which ones broken or just get good used or new replacements for them all. New they are pretty expensive but should be easy to find some good used ones.
kmartinez1
kmartinez1's Avatar
How many miles are on the car?
Old 03-05-14, 09:03 PM
slvrboolet
slvrboolet's Avatar
172k I think he said. Is the noid something that can be easily replaced?
Old 03-06-14, 07:42 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Solenoids aren't too hard, definitely not a 2k job for somebody else to do, and most definitely not worth trashing the SC over.
wannabe
SC- 1st Gen (1992-2000)
02-02-19 12:40 AM
El28
Build Threads
11-21-17 06:18 AM
COOLIS
50
08-27-15 02:34 PM
Neil4Speed
Maintenance
07-14-06 12:01 PM
Quick Reply: Sc400 won't reverse
