Where should a 1uz idle (sc400)
Old 03-07-14, 05:01 PM
tenac2215
tenac2215's Avatar
Default Where should a 1uz idle (sc400)
Just cleaned out my iac valve and was wonder where the 1uz is supposed to idle normally. It's a 93 by the way. Thanks!
Old 03-07-14, 05:37 PM
MongooseGA
MongooseGA's Avatar
Mine is right around 500-550, but I think that's a tick low. I think I read on here somewhere between 6-700.
That's without the AC compressor on. AC on, mine idles at maybe 800ish.
FWIW, my engine runs perfectly. No hiccups or anything to note.
Old 03-07-14, 05:38 PM
iridebmx
iridebmx's Avatar
600-800 rpm fully warmed up. first start up around 1100-1300. for me anyway...
Old 03-07-14, 06:02 PM
ArkLaTexSC
ArkLaTexSC's Avatar
Mine shows at about 3-400, and 200 with a bad coil! Then again, I have a SC300 dash, so raise those numbers by 33%. It's still funny to be at a stoplight and (with my exhaust) have it idle so low that it sounds like a lumpy-cam 60's muscle car. Gets the best looks.
Old 03-07-14, 07:36 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Mine with a newly rebuilt ECU and maladjusted TPS idles at 1300 when cold, 1100 when warm. Should idle at about 700 when warm with A/C off.
Old 03-08-14, 06:55 AM
Studiogeek
Studiogeek's Avatar
I think mine is between 5 and 6 when warm (ill check today) but even after cleaning the IAC last week still sends my aftermarket volt meter into the RED (12v or less) when warm, in drive and stopped at a stoplight. 3 times it went down to 11 volts and died at a light with accessories on. I have to shift into neutral at stoplights and rev it a bit. It stays in the green much more often with the AC on. I am on my third alternator with a new battery. Is there another way to raise the idle a bit? Could it be my ECU?
Old 03-08-14, 08:38 AM
ArkLaTexSC
ArkLaTexSC's Avatar
Check engine grounds. Clean em up.
DopeSC400
08-22-18 06:32 PM
salimshah
03-31-16 06:06 PM
edbro
RX - 1st Gen (1999-2003)
09-29-07 09:08 AM
aumsc400
12-31-05 05:56 PM
GSquicksilver
Performance
12-01-02 02:19 PM
Quick Reply: Where should a 1uz idle (sc400)
