O2 Sensor Extension Harness
Old 04-13-14 | 08:34 PM
Soarin2jzg's Avatar
Soarin2jzg
Default O2 Sensor Extension Harness
Does anyone know where I can buy a plug and play O2 extension harness for a 1994 sc300(single wire)? Bought a new header and the OEM O2 wires are way too short. Don't really want to start cut and splicing unless absolutely necessary.
Old 04-13-14 | 09:44 PM
oldManTan's Avatar
oldManTan
its only 2 wires to splice so it's not that bad... just saying lol
Old 04-14-14 | 10:08 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
there are none, get some wire cutters and some crimp on connectors if you can't solder and start having some fun.
Old 05-02-14 | 12:27 PM
1997Soarer's Avatar
1997Soarer
Casper Electronics makes O2 extension harnesses.
But it looks like they are for 4 wire sensors.
If you do have 1 wire sensors, it's just best to cut and extend it. Just use solid connectors and waterproof them with heatshrink tubing
Old 05-02-14 | 12:32 PM
SCereal's Avatar
SCereal
Home Depot/Lowes sells these butt connectors that have solder in them already and heat shrink tubing around them. They work great. Just slide it over one end, twist the ends together, slide it over the joint and heat with a heat gun. it'll melt the solder in and make a good connection then shrink the tubing around it all in one shot. They're transparent so you can see the solder is good as well.
Moarpower
09-20-17 02:10 AM
Cavedog
10-29-15 01:38 PM
93MSB
07-14-11 11:10 AM
J_LS
05-11-09 01:44 PM
