camry throttle cable routing 1jz
hey guys,
so i've read that the Camry throttle cable is pretty much required for doing a 1JZ swap on the SC but it is a bit long now that i put it in there. how did you guys route it and modfiy the throttle bracket to be able to bolt it on?
this is how it sits now
![camry throttle cable routing 1jz-ox4v0vi.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/497845d1683164081t-camry-throttle-cable-routing-1jz-ox4v0vi.jpg)
cheers
Marko
cheers
Marko
hmm interesting, i may have to look into something like that as well if i can't figure out a good solution. i really need a different throttle cable bracket too.. time to go to junkyard and buy a bunch of different toyota throttle bits i guess. lol.
how did you attach the lokar cable to the gas pedal? that connection is different from the OEM
RedPhoenix
SC400 / 300 Classifieds
06-14-11 06:39 AM
