When replacing Rack & Pinion and P.S. pump, can you somehow damage the clock spring?
Hi,
I had a shop replace my rack and pinion and power steering pump (and UCA/LCA) yesterday.
When I got it back, my airbag light was on and my horn did not work (they were fine before).![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Is there any possible scenario where the clock spring could be damaged while changing the rack and power steering pump?
Is it just a bad, untimely coincidence or could they have broken it? If so, how?
If I bring it up, I want to be able to present a reasonable case for it being their fault or I will just let it go and pay for it myself.
SG
EDIT: I JUST REMEMBERED, THEY ALSO REPLACED MY LOWER STEERING SHAFT.
Does this add anything useful to the diagnosis?
SG
I'm going to PM you on FB about this. I think they did something stupid and removed your airbag for some reason. Did they inspect your steering column or something? I remember another thread a few days ago where you discussed some shop checking out your steering column.
I have some suggestions for you. I bet someone lazy didn't hook your airbag or horn up after removing the airbag.
Thanks Guys!
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I did not notice it until i was a few miles away and the mechanic left when I left as it was late in the day. I did not want to go back in there without a proper case or argument so I called and let them know the issue and I came here for a bit of education to support my case first. Someone told me they must take the steering wheel off to align the wheel when changing the rack and at least that puts them in the area of the "broken" part.
Don't worry, I'm going to get them. I just didn't know enough before I gathered information first.
Any other info on what mistake they could have made to cause this would be greatly appreciated.
I will surely make sure they don't pull the bulb but that won't help with the horn ;-)
Thanks V
jdub20tx
Performance & Maintenance
08-08-12 06:29 PM
GziN'300
GS - 1st Gen (1993-1997)
06-23-09 08:16 PM
