Idle Problems
Old 05-28-14, 10:36 AM
Dtaylor3
Dtaylor3's Avatar
Unhappy Idle Problems
Yesterday I changed my spark plugs from Bosch to the NGK platinum. I now have this weird problem while idle, the car kinda stutters and acts like it wants to cut off. Any fixes for this?
Old 05-28-14, 10:53 AM
t2d2
t2d2's Avatar
My idle was acting kinda funky after miscellaneous engine bay work. I saw a thread recommending to change out the old, dry rotted vacuum hoses. It's only been a couple of days, but I haven't noticed an idle issue since. Some of my hoses were in pretty rough shape, so maybe one of them got disturbed just enough to throw things off?
If you want to give it a shot, it's 5/32" (or 4mm) and you'll need anywhere from 6' to 11', depending on whether you want to change out the three longer runs. I picked it up for ~$1/ft at Autozone.
I'm also wondering in your case if it could be something about the plugs/wires themselves. Did you use dialectric grease?
Old 05-28-14, 11:38 AM
Ali SC3
Ali SC3's Avatar
you probably missed a vac hose somewhere.
Old 05-28-14, 12:31 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Like Ali said, you probably missed a vacuum hose somewhere. There are so many it's like navigating around Los Angeles.
Old 05-28-14, 01:33 PM
Ozzzzy
Ozzzzy's Avatar
How many VAC lines do you have to remove to just replace the plugs?
Old 05-28-14, 02:31 PM
Dtaylor3
Dtaylor3's Avatar
t2d2- I did not use any grease. you think that would help
Ozzzzy- If i remember correctly i only had to take 4 hoses off to get to them
Old 05-28-14, 03:42 PM
INTIMAZY
INTIMAZY's Avatar
You didn't connect one of the plugs.
Old 05-28-14, 04:13 PM
t2d2
t2d2's Avatar
I've never compared with/without, but I'm told it's important.
Old 05-30-14, 02:15 PM
Dtaylor3
Dtaylor3's Avatar
I've tried everything you guys suggested and still no luck. I even went back to my old spark plugs. I also get some black smoke from exhaust when i give it some gas. It seems like its burning too much gas cause i can smell it too. Any suggestions?
Old 05-30-14, 03:13 PM
Ali SC3
Ali SC3's Avatar
you may have a bad wire now or something like that. did you change your cap and rotor ever? did you start having the problem before you changed plugs or only after?
Old 05-31-14, 07:51 PM
Dtaylor3
Dtaylor3's Avatar
I have not changed the cap and rotor lately. I didnt start having the problem until i changed the plugs.
Old 06-03-14, 10:28 AM
Dtaylor3
Dtaylor3's Avatar
Still having the problem... Idk what else to try
TechGreek
41
03-20-19 07:58 AM
m1k3yg
GS - 1st Gen (1993-1997)
04-19-12 08:20 PM
boxcarfan
10-10-08 09:27 PM
envyno1
03-15-08 08:33 PM
LeXuSrAcIn
RX - 1st Gen (1999-2003)
12-17-06 11:20 AM
Quick Reply: Idle Problems
