IS300 Fans - How to wire them
Old 06-07-17, 07:22 PM
  #46
SCott300
SCott300's Avatar
Originally Posted by gerrb
You would need the 3 switched / fused supply to come through the ignition switch or they will always be powered on . It will drain your battery.
The other two you can bring the fuse directly through the battery since they won't be powered on till the relays are on.
What size fuses should I use?
Old 06-08-17, 04:08 PM
  #47
gerrb
Super Moderator
gerrb's Avatar
10 amp at least for each of the relays and 30 amp at least for the fans
Old 06-19-17, 11:42 AM
  #48
SCott300
SCott300's Avatar
I used two "add-a-fuse" circuit taps for my two 10 amp relay fuses, but how would you suggest that I tap my three 30 amp fuses into an ACC power source? Can I unscrew the power wire that leads into an ACC fuse in the box under the hood and tap my 30's in that way or will that over load the circuit?
Thank you for all your help
Old 06-19-17, 01:19 PM
  #49
gerrb
Super Moderator
gerrb's Avatar
the three 30 amp fuses that are for the fans go directly to the battery , then relay switch then fans
only the 10 amp fuses that control the actual relay are switched so they are not always on.
Old 08-02-17, 04:54 PM
  #50
Osbornecox
Osbornecox's Avatar
The pics aren't showing up on my end. Gerrb, any chance you can put the back up?
Old 08-09-17, 12:35 PM
  #51
Halon
Halon's Avatar
FWIW, I love my IS300 fan setup. I actually bought a new 'OE-Aftermarket' version of the fans that I've been running all year (made by Sunbelt). I personally just wanted something new rather than a used set of actual OEM Toyota ones, so I gave em a shot.
https://www.amazon.com/RADIATOR-CONDENSER-LEXUS-IS300-LX3115108/dp/B004A6K5GO/ref=sr_1_1?ie=UTF8&qid=1502306230&sr=8-1&keywords=is300+radiator+fans https://www.amazon.com/RADIATOR-CONDENSER-LEXUS-IS300-LX3115108/dp/B004A6K5GO/ref=sr_1_1?ie=UTF8&qid=1502306230&sr=8-1&keywords=is300+radiator+fans
There was some question as to whether they would work as good as the actual Toyota ones as the fan blade design is different. But I can attest that they do in fact work excellent. Mine is setup to just use the stock temp sensor and is controlled by my standalone. We have em setup to kick on at 190 and shut off at 180. No low speed control, just both On Hi-Speed or both Off. We don't see AZ temps here in MN, but we've had days near 100* where I have the A/C running on full blast, and it all still runs like a watch. My temps never even reach 200 under normal driving even on the hottest days we get up here. Highly recommend this setup to anyone interested in switching over to E-Fans. The built in coolant overflow is really nice as well.
I did adapt these to fit on my OE Denso SC300 radiator. The simple brackets I made, I've uploaded the design to the 'CAD File Sharing' thread on here for anyone else who wants to use them. It's a very basic/crude means of adaption but it works and costs hardly anything, and all the measurements are right there for you in that thread making it super simple to make your own. One of my local friends here is working on a much nicer and more elegant adaption setup that I can't wait for him to finish. It'll cost more but is really nice.
Old 08-10-17, 03:52 AM
  #52
gerrb
Super Moderator
gerrb's Avatar
gosh ... this photobucket mess
I would have to go through thousand of pictures and see what I can do .
Old 08-10-17, 04:44 AM
  #53
gerrb
Super Moderator
gerrb's Avatar
Pictures for this thread are now posted on Post #4116 Page 275 of my Build Thread https://www.clublexus.com/forums/bui...ml#post9950386
Slowly I will post all pictures I have posted on different DIY threads in my Build Thread.
Old 08-12-17, 05:33 AM
  #54
Osbornecox
Osbornecox's Avatar
Thanks Halon & gerrb.
Old 06-04-22, 04:31 PM
  #55
Ayotriple
Ayotriple's Avatar
Bumping this amazing thread back up… loads of helpful information to read but I have a few questions for Gerrb. I read all the post on different ways to hook up the fans, since I’m still on OEM ECU I’m leaning towards using the coolant temp sensors to run the fans. Only thing is I purchased a PHR dual fan PnP kit, and I’m about to order OEM replacement IS300 dual fans, is there anyway to incorporate the PHR kit into the coolant temp sensor setup? That way I actually use the kit and don’t just let it sit there and be a waste of money. Thank you for any help in advance.
pga88
12-15-10 08:51 PM
chuckn
IS - 1st Gen (2001-2005)
16
08-17-10 11:04 AM
Quick Reply: IS300 Fans - How to wire them
