SC300 1JZ Starter Problem
Old 08-19-14, 08:39 PM
504SC
504SC's Avatar
Default SC300 1JZ Starter Problem
I replaced my starter on my 1j this evening because I got the one click and done problem with the previous one. I got an OEM starter for a 1j. Installed the bad boy and and got nothing, no turnover nothing. Everything powered up fine, but now crank. Trying to figure it out I noticed the positive battery cable was getting hot. Not normal of course, so I figured I have a bad connection or ground out somewhere. I tightened the cables to the battery clamps, connected the negative and as soon as I touched the positive to the battery post the starter engaged and started spinning. What the hell is going on here? I cant leave it connected because the starter just continually spins. Any ideas or advice would be greatly appreciated!
Old 08-20-14, 07:57 AM
BiGEZ
BiGEZ's Avatar
Did you check the ground connection on the engine block? Sounds like you have a ground connection issue recheck all your connections.
Old 08-20-14, 09:05 AM
Vrank
Vrank's Avatar
Has the car ever started and run properly since it's been swapped?
Old 08-20-14, 09:08 AM
504SC
504SC's Avatar
All looks to be fine, I will double check again to make sure.
Old 08-20-14, 09:09 AM
504SC
504SC's Avatar
Yes the car has ran fine for years.
Old 08-20-14, 09:11 AM
Ali SC3
Ali SC3's Avatar
sounds like possibly a bad connection or starter. I would have just replaced the contacts in the original one you knew was working.
Old 08-20-14, 09:50 AM
504SC
504SC's Avatar
Well I replaced the starter cause of the one click I received which started this mess. The new starter I put on obviously works cause when I connect the battery back it starts spinning.
maynanator
SC- 1st Gen (1992-2000)
03-24-10 08:39 AM
Max N Sac
12-21-07 04:08 PM
Craig7022
GS - 1st Gen (1993-1997)
08-08-07 02:57 AM
GS3Admired
05-27-07 07:27 AM
mosesgolf
01-23-07 04:28 AM
Quick Reply: SC300 1JZ Starter Problem
