helpp (SWAP)
hey guys iI need some help,I bought a 7mgte 154 and I'm planning on doing a 2jzgte swap next year but for now I need to put the r154 into my sc300 bc my w58 is *ucked! what do I need to complete the swap????
If I read correctly since your SC is already 5 speed and you have the r154 all you'll need is:
1jz bell housing
1jz flywheel
clutch setup
(toyota 4age iirc) arp flywheel bolts
supra r154 front half of driveshaft
clutch fork
slave cylinder
marlin crawler vss converter
shifter housing extended
1jz bell housing
1jz flywheel
clutch setup
clutch fork
slave cylinder
madmax98
Performance & Maintenance
08-12-08 12:19 AM
marek955i
12
12-27-07 12:47 PM
