sc300 wont start anymore!
Hey everyone, I have a 1992 sc300. Its been fine for a couple months, but now it wont start. Its givin me a problem before where it would crank after the 5th time i tried starting it, but it ended up starting. Now it wont crank at all. Ive checked all fuses, all wires going to fusebox, redid my nss, checked to see if starter is getting power, checked and tested starter relay, checked all grounds, checked battery, reset my factory alarm, i even tried to run the nss a different way.
Everything checks out!!! I have a friend who suspects the ignitor, but the car wont crank at alll!!
Only thing i havntt checked is the connection between the ignition switch and the starter. Any advice on how i could check that?
Car is 1992 bone stock with r154
I also cant run any codes i already took my battery out
If the car wont CRANK, its the starter. If it will cranks, but wont start its something else. However, the ignitor has nothing to do with the starter not turning/cranking.
If you have already checked everything, and based on what you have listed it seems like your starter went out. Just cause its getting power, doesnt mean it will turn. Pull the starter, and have the entire unit tested.
dkillrstr
09-01-14 08:24 PM
