Weird Issues With SC400
I just recently bought a 1995 SC400 in Jersey City, NJ. I decided I was going to get it there and drive it home since the price was amazing for the car. I couldn't do the whole drive that day due to scheduling issues, so here are the problems I am presented with on the short 4 hour drive:
1. Whenever the steering wheel is turned to the left at a certain angle, there is a sound that seems like there is something bouncing against the frame or the car or the wheel.
2. Anyone know about any transmission seals? I was told the noise that would come from the center console of the car that made it really sound annoying was because there was no cover to block the sound from the transmission.
3. When I completed the drive to my uncle's house where I left it and parked the car, there was some smoke coming from the engine bay, and it sounded like rubber was burning. How can you tell if it is the brakes, the wheels, or maybe a part of the engine that I may need to be concerned more about. The length of the drive was 217~ miles, if that helps any.
The smoke seemed to be coming from the left side of the engine bay if you were looking at the car straight on. It drove fine for 200 miles, then when I stopped and parked it I smelled that burning rubber smell and saw the smoke. It wasn't a TON of smoke, but it was still enough to raise some concerns.
I can tell the smell of tires and clutch, but I don't know brake pads and plastic. I'm not near the car currently, so I can't check, but when I get a chance, i'll post a pic/video here of the issue.
Sounds to me like either a valve cover gasket is leaking oil onto the exhaust manifold and is being burned, or the tire is rubbing and smoking. If it where something on the front of the engine causing the belt to smoke, I think you would have warning lights on.
I was going to suggest checking the wheel well liner, sometimes parts of it can crack and it can hang and rub on the tire. Enough friction can cause smoke, you can just use scissors to cut any bits of the wheel well liner that are dangling down. I had the same problem with my car driving me mad until I discovered it was an incredibly simple thing to fix.
Sucks the car got hit though, how'd it happen? Hopefully you had it insured right?
Bad news, but there's a very large probability it will be totalled. The rear quarter panel damage alone is enough for most shops to total it out. Hopefully they give you a good bit of cash so you can find another one though. I understand what it's like as these cars really can grow on you.
Shobbs008
Performance & Maintenance
05-23-17 09:45 AM
aer6438
RX - 1st Gen (1999-2003)
20
05-09-15 06:05 PM
Sonicboom1
04-12-13 10:51 PM
