cel code 52 on a lexus sc 300
Old 09-18-14, 08:03 PM
unknown101
unknown101's Avatar
Default cel code 52 on a lexus sc 300
I had a cel code of 52..which is a knock sensor number1....I read a bit about it and it said that the knock sensor could cause a lost of power...which is how my car feels right now...This problem is comming from my 92 lexus sc300...so does actually changing out the knock sensor will kill my cel??? Lmk...
Old 09-18-14, 08:54 PM
soarer13oy
soarer13oy's Avatar
Check the wires to it, if theyre good then replace the knock sensor.
Old 09-18-14, 09:31 PM
turbodremz
turbodremz's Avatar
Yes a knock sensor can cause a loss in power, but generally will at times kill the engine. Replacing them is pretty simple, but if that is the code your getting then as soarer stated, check the condition of the wires first. If they are good, then replace the sensor.
Old 09-19-14, 01:08 PM
unknown101
unknown101's Avatar
Does anyone got a picture of the wire?? Any where can I buy one....can't seem to find it on ebay
Old 09-19-14, 02:08 PM
soarer13oy
soarer13oy's Avatar
You can probably get the plug with pigtail from toyota but you cannot just buy a wire and simply install. Like i mentioned above check to see if the wire looks brittle if not then replace the sensor.
Old 09-19-14, 02:45 PM
unknown101
unknown101's Avatar
Do u have a pics?? Sorry I'm ma noob a the sc300...jus bought the car 3 months back..and if I had to replaced the knock sensor..While taking out the intake manifold what else do I need to replace since some parts is off alreafy..like gasket?
Old 09-19-14, 02:48 PM
soarer13oy
soarer13oy's Avatar
Sorry i dont have any pictures. I would recommend you doing the valve cover gasket and possible plugs if you havent already.
Old 09-19-14, 02:54 PM
unknown101
unknown101's Avatar
Jus wondering can u jus the knock sensor with the wire from ur local auto part store?? And if u get it from the dealer u no the price range??
Old 09-19-14, 03:13 PM
soarer13oy
soarer13oy's Avatar
you can probably get the sensor from a parts store but you cannot get the plug.
Old 09-21-14, 09:01 AM
Candela
Candela's Avatar
I had this issue. It happened to me because I was taking off the intake manifold, got frustrated and yanked on it without realizing there were still things plugged in. Needless to say several plugs ripped, I fixed them with *additional thicker gauge* (wrong) wire, and the circuit fault codes were trigged. Went back and removed the extra wiring and soldered stock to stock and its gone. Sometimes a cheap sensor may cause that too i've heard
Old 09-21-14, 11:50 AM
unknown101
unknown101's Avatar
Any forums on how or what to take off to get to the sensor??
Old 09-22-14, 02:45 PM
Candela
Candela's Avatar
I hate to be the bearer of bad news but you're gonna have to completely remove the intake manifold to be able to do your best job at fixing the wiring and even removing the sensor.
Old 09-23-14, 03:19 PM
unknown101
unknown101's Avatar
Thanks...I kinda figure that out..but is there a thread on how to remove it?
2ks
RX - 1st Gen (1999-2003)
78
06-13-20 08:21 PM
Rbeeber
12-02-18 08:42 PM
pkpmusic
12-09-13 06:00 PM
LexusBiz
01-27-03 02:41 AM
Quick Reply: cel code 52 on a lexus sc 300
