VVTI Feedback Needed: NA-T or GTE
If we are talking swaps most swap it to a manual or use a gte auto trans that came with it. I don't know any swap that someoe re-used the GE trans with a gte motor.
on na-t maybe people have had it hold 400, but for how long?
300 to 350 now that sounds more doable with a cooler.
400+ range is what the gte auto's can handle.
The gte trans will have a larger toque converter and more clutch packs than the n/a auto.
I dunno where you got 400whp on the GE trans, 400hp will surely destroy it its just a matter of time.
shimming will only take the pressure off from shifts and the cooler can only help so much when you start laying power down with the smaller internals.
check out this thread now that clubna-t is back online. some good info here and there
http://forum.clubna-t.com/showthread.php?t=4145
For what they cost there is no reason not to start with a Gte auto trans. Im not saying running the GE won't work, but I wouldn't have it in any build plans, I would just use it for the time being until you choose the setup that will work for the long run.
I agree!
I agree that the non vvti gte setup is tried and true. However when it comes to the gte, vvti and non-vvti use the same bottom end. My car came with the vvti motor, so I want to keep it vvti and the gte vvti seems like the best option, especially when using the stock gte vvti ecu and tranny.
I agree!
I agree!
Thanks! I'm a bit hooked on the late 80s/90s cars. The thread actually clarified a lot, which helped me decide, especially on the tranny choice.
