throttle body click away when ignition on, engine and traction light on
Car was idling high had a bright idea to remove the secondary tps when install it on bk with ignition on it would click away, took it to mechanic he calibrate it and it still makes noise still having the problem. .
That was quite difficult to comprehend, but if I understand correctly, you removed the TRAC (secondary) TPS while the vehicle was running, now TPS is clicking and is still clicking after your mechanic attempted a calibration.
Reset ECU, if it still clicks, the TPS needs replacing.
AlaskanLS
26
02-27-17 02:52 PM
LsG86
02-28-15 09:35 PM
Drewbeeee
Performance & Maintenance
07-21-08 09:15 PM
TRULUX
09-01-04 08:53 PM
