No Start SC300
Old 10-18-14, 05:03 PM
RedMansSC3
RedMansSC3's Avatar
Default No Start SC300
Just sharing my adventure today.
The car ran fine. I was attempting to adjust the TPS to see if that was the random stall problem I had. After adjusting the TPS voltage signal the car started then stalled. So the car would crank, then catch for a second or a few and shut off. Then cranking more times, it would not catch at all. At first it would catch for a few seconds each time I adjusted the TPS in a certain voltage range so I thought it was due to the TPS. An hour later I decided to give up on the TPS and move to engine light, spark, fuel and timing. Engine light was a continuous blinking so no luck there. I had spark and timing belt was still timed correcting. At the fuel pump I didnt have 12v. Switched the relay with the defroster. No luck. I was loosing power at the fuel ecu. So did the 12v bypass and shes all good now. Starts up. Tomorrow I will finish adjusting the tps, idle and the small things.
Old 10-19-14, 03:03 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
I tried setting the TPS on my SC to spec, but it ran worse so while the car idled, I moved the TPS counterclockwise/clockwise till the idle was about 900 RPM's in Park and 500-600 in Drive.
Old 10-19-14, 05:53 PM
RedMansSC3
RedMansSC3's Avatar
Once I got the car running, I used the idle screw to drop my rpm's down to around 600 then rechecked to make sure my tps was still in spec. Running so much better now, I think my fuel ecu was cutting in and out while I was driving before or keeping it at low voltage. I use to have random bogs while driving.
Jesse1984
02-19-13 07:20 AM
Nissanfan
IS - 1st Gen (2001-2005)
02-02-13 03:00 PM
ezsls400
35
09-08-11 02:11 PM
rblinn
08-30-11 07:13 PM
Fhanatixs
SC- 1st Gen (1992-2000)
06-28-11 11:11 AM
Quick Reply: No Start SC300
