Heater blowing cold air and the air smell bad.
Hello. At the beginning i want to apologize for my english, because i am not speaking so good.
I got a problem here with heating, heater core. I got this problem since 2-3 years but finally i want to have it solved. The problems are:
1. When i press 'gas' and put the car or high rpm 3000+ it blow hot air, but not so hot, just a bit. More rpm makes more temperature. When i just leave a car on "P' (parking) its cold air all the time.
2. Inside the car is a bad smelll when its heating. When i put the a/c on, and blow cold air, smell is fine. When i change the temperature to high then its a problem, smells very bad.
My thermosthat is ok, the coolant fluid is filled full, valve control or something, is fine also. I tried the overpass previous year, and its still the same.
I saw the guy selling on polish auction site all the heater system, very cheap. From the english 'toyota soarer' should i maybe but it and replace? Soon we got a winter in here so i cant flush the heater with any kind of fluids because the temperature is going on minus in here.
First of all, your English is much better than many of the supposedly English speaking people.
I would start by investigating what aspect of the heating system is RPM dependent. (My guess would have been none!) That might provide a hint of what's going wrong the rest of the time.
ancdmd
08-15-10 08:18 PM
