fuel pump relay
Old 12-20-14, 11:54 AM
equix8
equix8's Avatar
Default fuel pump relay
Hello, I have a lexus sc300 2jz-ge engine and gearbox a340e, I wonder where is the relay for the fuel pump q is failing me, sometimes .enciende and off. and They Said it was her fuse or relay but can not get Its location in the vehicle, cualqueir serious answer helpful. thx:
Old 12-20-14, 05:00 PM
bigwhite
bigwhite's Avatar
Its in the fuse panel under the hood, the panel has 2 screws holding it down. The diagramn is under the cover. If that dosent do it I had to replace the main ECU and the fuel pump.
Old 12-28-14, 10:31 AM
INTIMAZY
INTIMAZY's Avatar
The fuel ECU can (and SHOULD) be bypassed. You can use a 12v switched and a basic SPDT relay to power it directly off the battery.
It's much easier to troubleshoot than the headache the fuel ECU puts you through.
Old 12-29-14, 04:55 PM
bigwhite
bigwhite's Avatar
He seems to be asking about the relay first, but I through in the other for good measure.
Old 12-29-14, 05:02 PM
kornpeef
kornpeef's Avatar
most likely the pump is going out. when u turn the car on not start but to the on position can u hear the fuel pump turning on. I think you can get access to the fuel pump under the rear seat cushion. if you can get to the electrical connector and check for power and ground there. its a new pump for you my friend.
Old 01-03-15, 09:04 AM
equix8
equix8's Avatar
thank you very much for your answers, solve achieved by changing the ECU relay works perfect "for now". I have another question, my SC300 is 96 and does not have the traction control button, remove the console and saw two connectors coming from behind to come Differential my question is can apply this model traction control? thx
Desacatao
03-03-19 03:09 PM
jose2015
13
03-13-15 11:53 AM
KickItOut
02-03-13 04:21 PM
sc300vroom
SC- 1st Gen (1992-2000)
11-07-09 08:31 PM
dave_id
10-24-09 01:43 AM
Quick Reply: fuel pump relay
