Door interior trim panel reassembly
The previous owner of this 92' SC400 removed all the upholstery panels on both doors. Also he lost the armrest bolsters. Been looking for a exploded diagram of the door trim and all parts.
Trying to put the drivers side upper window surround and main panels back on.
Obviously ONE problem is the missing ARM REST bolsters. So for now the switch assembly is going to hang there.
BUT it seems the "switch panel assembly" wiring harness it too short...hard to think it is but is this a REALLY tight fit?.
Trying to pull the switch holder through the hole in the door panel and out far enough to get it into the bolster wiring harness just seems too short...not likely unless the main door panels are NOT the correct 92' SC parts.
Anyone recognize the door panel as the correct piece...? the hole seems too low for the length of the wiring harness...again, not likely but has me wondering.
OK if the door panel was popped into place the extra inch closer to the door may be all that is needed, but with the bolsters added on sure won't be much slack.
Anyone know if the window trim goes on first? or does sequence of assembly matter?
Any ideas or recent experience with this job?
Thanks, Pete
Thanks, Pete
the armrest piece covers that big hole then the switch pannel snugs into a hole in the armrest piece. looks like you're only missing the armrest pieces/screws.
the switch harness is normally pretty short. not much slack to work with, but the switch panel can be disconnected by the white and blue connectors.
imo, the tan panels are dime a dozen you can easily find some cheap maybe even in better shape, check some local junkyards/craigslist part-outs.
https://www.clublexus.com/forums/sc-...el-repair.html
In this awesome thread, O.L.T. shows how to repair if the plastic tabs break, the first few photos show how the panel comes apart and how short the switch harnesses are. most likely the reason why yours are missing.
Stone,
Thanks for the post and reference to the thread...that thread has GREAT photos which is what I need along with a reassurance the wiring harness is tight but doable.
Had some concern the panels that came with car were not correct...stranger things have happened.
Thanks again.
Thanks again.
wow. haha. I just literally finished installing my door panel that I took apart today to dye. lol. if I would've known I would've taken a video to show you. but not to fear, I have another door panel for the passenger side that i'm doing the same thing too. so i'll take a video when I do.
mdfdsc300
01-19-12 04:48 PM
BinaryJay
09-19-10 08:56 PM
