what differential is this? will it work in an SC400?
anybody know what kind of differential this is. the seller says its a 2jz supra/aristo twin turbo automatic differential. that would mean its limited slip right? would this mount onto an sc400 correctly? any insight is greatly appreciated!
the ones from overseas are misleading cause LSD was an OPTION. over here if you find a twin turbo automatic diff from a supra its pretty much going to be LSD but thats not the case with the diff's from overseas always, and the ones from Japan they already know if its LSD or not, so if the price is lower its most likely open diff and not that you found a good deal generally.
If you see that round "Bar" in the middle of the gears like in that picture, its non-lsd.
