Strange ignition issue
Old 02-06-15, 12:33 PM
zeus87gn
zeus87gn's Avatar
Question Strange ignition issue
Our SC400 went to sputtering and running badly a few weeks back
This happened 'all of a sudden' from running just fine when leaving a parking lot
In the course of trying to solve the problem, I have replaced all the plugs, wires, caps & rotors
All these parts have no miles on them, but I have went around the block in our neighboorhood (20mph if I could get there) and idling in the driveway
I ran a compression check which turned out fine (didn't jump time) but discovered that 3 of the 4 new plugs that are fired from the left coil are not firing - that 4th plug and the other 4 on the other coil have signs of firing, but these 3 are still brand new appearing and wet with fuel
Why would 3 of those 4 plugs not be firing?
Cam sensor?
ECM?
I confused
Any and all help is appreciated
I need to get this poor old thing back on the road
Old 02-06-15, 01:55 PM
oldManTan
oldManTan's Avatar
ignition coils, one is by the driver side header, the other on the passenger side in the front of the engine. unplug one and see if the car starts, the one that the car doesn't crank with is the bad one.
Old 02-07-15, 07:22 AM
zeus87gn
zeus87gn's Avatar
Both coils are new - all ignition parts are new
Only 1 of the 4 plugs on that coil are firing
Old 02-07-15, 11:37 AM
oldManTan
oldManTan's Avatar
hmmm, all i can say is check the wiring i guess, i can't think of anything right now.
Old 02-10-15, 06:24 AM
zeus87gn
zeus87gn's Avatar
TTT for the morning crowd
Old 02-10-15, 06:26 AM
zeus87gn
zeus87gn's Avatar
I guess I should also note that I don't get any codes from the computer on this
Its not the original computer, ist one I purchased from a fellow on the board
It physically in good condition - no burnt components, still has a new smell to it
Old 02-12-15, 05:55 PM
bigwhite
bigwhite's Avatar
No major vacumn leaks? Fuel filter been replaced? Ecu can look good but be bad.
Old 02-14-15, 11:03 AM
zeus87gn
zeus87gn's Avatar
No - no major vacuum leaks
Fuel filter was replaced some time ago
the plugs are getting fuel - they're not getting spark
ItsAV8
03-27-19 08:09 AM
mzeitlin
17
10-10-11 12:36 PM
Jstoked
10-03-11 01:35 AM
lexusflex
01-15-09 06:43 AM
Quick Reply: Strange ignition issue
