cant get timing belt on
Old 02-08-15, 10:07 AM
erock202
erock202's Avatar
Default cant get timing belt on
Is there a trick to this I can't get the belt to go on seems as if idler pulley is in the way
Old 02-09-15, 12:04 AM
salimshah
salimshah's Avatar
Received 1,045 Likes on 943 Posts
With the tensioner off, if you have the right belt, there should not be a problem.
You can make sure you have the right belt by comparing and counting teeth of the old belt.
Start by matching the main pulley mark and go CCW facing the engine. Move the drive side cam over to create a slack, match mark and then rotate back to take away slack. Then move over to pass side cam and do the same.
Good luck
Salim
Old 02-09-15, 02:00 AM
erock202
erock202's Avatar
Thanks i got it now
mooseboy84
10-31-15 11:35 PM
Sololock
26
05-30-12 08:56 AM
Vadim540i
SC- 1st Gen (1992-2000)
11-28-10 11:42 AM
kez
07-24-10 06:41 PM
rx7guy
04-29-09 12:27 PM
Quick Reply: cant get timing belt on
