sc300 dies after 10 feet wont restart for several hours.
Old 02-13-15, 12:45 AM
paco5150
paco5150's Avatar
Default sc300 dies after 10 feet wont restart for several hours.
Help!!!!!!! 1993 SC300 keeps dying then wont restart. Engine cranks.but wont start. A lexus master specialist: no codes, quite possibly the mass air control sensor is out. What do y'all think????! I dont want to give up on this car!!!!! Any advice is helpful, wife want me to get rid of it. Negative.
Old 02-13-15, 08:54 AM
Ali SC3
Ali SC3's Avatar
Welcome to CL. check out the 12v fuel mod, you could have a bad fuel ecu which causes them not to start.
could be lots of other things, how bout a little more info on the car, mileage, maintenance you have done. etc..
Old 02-13-15, 02:52 PM
paco5150
paco5150's Avatar
thx for replying. just a regular car no mods. 197000 miles on it, automatic. puchased a used mass airflow sensor earlier, going to put it on after work......hopefully thats it. what kind of symptoms if its the fuel pump? what kind of symptoms for a bad fuel ecu? this car is so ****ing strange. no codes, no check enjine light. turns on just fine, idles great and strong then put in to drive, within 20 feet, dead, wont turn on. i would have to wait several hours for it turn on again.
Old 02-13-15, 05:43 PM
t2d2
t2d2's Avatar
The part about it having to wait several hours to start again makes me think it has to be either ECU or fuel pump ECU. What else would have a reset period like that? The fuel pump ECU seems less likely, but you can test it out by jumpering the Fp and +b pins in the engine bay diagnostic port to bypass it.
Old 02-13-15, 08:22 PM
paco5150
paco5150's Avatar
damn i wish i knew what that meant. how do you do that? video?
Old 02-13-15, 11:41 PM
t2d2
t2d2's Avatar
You've got the answer, it can't be that hard to search for the question now.
Old 02-14-15, 10:08 AM
paco5150
paco5150's Avatar
Narrowed it down to 3 things. Fuel pump, fuel pump ecu, or (probably and) this saturn looking thing. What is it? Sprayed some water/soap on it and lots of bubbles from the top.
Old 02-14-15, 10:32 AM
LoveSCs
LoveSCs's Avatar
can you take a different pic with it zoomed out a little more? That looks like its near the TPS sensor?
Old 02-14-15, 11:02 AM
paco5150
paco5150's Avatar
Anddddd: its not the mass airflow sensor. **** my nonmechanic life!!!!!
Old 02-14-15, 11:03 AM
paco5150
paco5150's Avatar
Love scs yes its to the right of it.
Old 02-15-15, 01:57 PM
paco5150
paco5150's Avatar
Ok. I did the bypass . Car turned on. Pulled the bypass paper clip, immediately died. I'm not smart enough to add this all together........bad fuel pump? Bad fuel pump relay? Annnnnnd. I pulled top of gas tank out, now the gas gauge isn't reading. fml!!!!!
Old 02-15-15, 03:16 PM
t2d2
t2d2's Avatar
It's not the fuel pump, because all you did was bypass the fuel pump ECU and that got it running. So, you can safely assume it's the fuel pump ECU. You can either buy a used one or just permanently bypass it with the "12V fuel pump ECU mod." I chose to drive around with mine temporarily bypassed (diagnostic box jumper) before cutting and soldering the pump ECU out of the loop for good. My pump ECU turned out to not be bad, but one of my car's quirks made it more convenient to permanently disable it.
Old 02-15-15, 07:18 PM
paco5150
paco5150's Avatar
Thank you. Not sure which option I'll choose but thx for the help. Hopefully this damn demon car will get going sooner than later. Still very very very very pessimistic that this is the solution . Lol.
Old 02-17-15, 10:22 AM
Ali SC3
Ali SC3's Avatar
the jumper bypasses the fuel pump ecu and your car turned on. its the fuel pump ecu.
my first post on here said you could have a bad fuel pump ecu, and it looks like you do.
its a very common problem, replace or bypass.
Old 02-17-15, 12:17 PM
eknine9
eknine9's Avatar
search for 12v fuel pump mod here on the forum. It's rather easy and will bypass the fuel pump ECU permanently. Most of us on here have done it to our cars, and it's one of the easiest mods I've ever done.
Quick Reply: sc300 dies after 10 feet wont restart for several hours.
