Car warms at idle, but temperature drops when driving
Old 02-17-15, 02:42 PM
tenac2215
tenac2215's Avatar
Default Car warms at idle, but temperature drops when driving
I have a 93 sc400 that seems to warm up only when idling, and then once I start driving, the temperature will start to drop. Them temp will usually drop to a little below the second tick in the temp gauge. I'm thinking this might be te thermostat? Any ideas let me know!
Old 02-17-15, 02:55 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Most likely the thermostat. This will likely affect your heater inside the cabin.
Old 02-17-15, 03:06 PM
tenac2215
tenac2215's Avatar
What do you mean? Like the heat doesn't get hot? Because it seems to Not really get warm inside
Old 02-17-15, 04:12 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
If the engine doesn't fully warm up you won't have any hot air from the heater. Your thermostat is likely stuck open. Same thing on my SC...won't get above 2nd tick on the temperature gauge sometimes, resulting in no hot air.
Old 02-17-15, 05:14 PM
tenac2215
tenac2215's Avatar
Alright that's what I was thinking. Just wanted to see some other thoughts. Looks like I'll
Be buying a new thermostat.
dlap
12-05-18 12:59 PM
Speedy0o
02-12-14 08:52 AM
mfb496
12-13-12 02:40 PM
Harlock
11-14-11 07:02 PM
keyfig
17
09-27-11 02:55 PM
Quick Reply: Car warms at idle, but temperature drops when driving
