Clutch Drops RPM's?
Old 02-19-15, 05:49 PM
Ozzzzy
Ozzzzy's Avatar
Question Clutch Drops RPM's?
My clutch started something new. Regardless of what gear it's in, even neutral, when I depress the clutch all the way down, or even close to the floor, the rpm's drop down 300-400 rpm's. Any ideas what causing this all of a sudden?
Old 02-21-15, 09:57 PM
Elroy19
Elroy19's Avatar
Are you running a heavy duty clutch? Sounds like a symptom of 'crank walk'
Old 02-25-15, 08:02 AM
Ozzzzy
Ozzzzy's Avatar
No. This is just the standard system. No upgrades
Old 02-25-15, 10:19 AM
Ali SC3
Ali SC3's Avatar
you could have a throw out bearing that is going bad or a mild case of beginning crank walk.
I think when you have a bad throuwout bearing in this case it can cause wierd issues and noises. do you have any whirling noises in neutral out of gear?
other than that it could be crank walk starting to happen, where the thrust washers are shot and when you depress the clutch pedal the crank rocks back and forth causing contact and wear with other parts and usually shows up as the rpm;s dropping. really hope that is not the case cause if it is then you will need a rebuild or a new engine eventually.
bypass the clutch start switch when starting the car now to help out in the meantime till you figure it out to prevent more wear on the thrust washers.
I bypassed my clutch switch several years ago and have not had any increase in it on mine and I have a ridiculously extreme pressure plate.
occasionally when I push the clutch in the rpm needle will move ever so slightly... not 100 rpm;s though that is kind of scary.
you could have some totally other random problem like something being worn or loose down there, like the throw out being siezed or something is worn, etc...
I would have someone who knows transmission poke around and see what they can find, especially since yours was stock crankwalk is hard conclusion to jump to right away no matter how good it fits.
Old 02-25-15, 12:43 PM
Ozzzzy
Ozzzzy's Avatar
First thing I did was bypass the switch. There was a squeaking noise when I started the car before I bypassed the switch and the pedal to the floor when starting. While the engine is running and I occasionally put the pedal to the floor or near it, there is no noise, just the RPM drop.
Old 02-26-15, 02:22 PM
Ali SC3
Ali SC3's Avatar
does it drop and then come back up? it doesn't sound good. may want to check the oil or drop the pan and inspect the thrust washers... cause if it is that, you will want to get to it before the crank takes a walk and a rod goes through the side of the motor. hard to imagine on a stock setup but I guess it can happen. still I would have an inspection of the clutch components first like pilot and throwout.. probably have to drop trans.
Old 02-27-15, 08:11 AM
Ozzzzy
Ozzzzy's Avatar
No, the RPM's are fine when I release the clutch. When this started I was assuming the throwout bearing. The other replies are talking about other possible issues. Won't replacing the clutch assembly fix this problem?
Old 02-27-15, 10:44 AM
SC3coupe
SC3coupe's Avatar
I think the throw out bearing won't drop the RPM this much. They are known for making whirling noise on these cars I heard, or at least mine is, but I check and no drop.
It surprise me you get a 400RPM drop, are you reading it correctly, does the tach starts at 500 at the base line?
You may need to confirm crank walk, I only know on some cars you take off the oil pan and use a pry bar to assess movement. You may want to check supra forums as this usually happens with heavy clutch that is common with modified cars.
Old 02-27-15, 01:29 PM
Ozzzzy
Ozzzzy's Avatar
I watched a video and they took a pry bar and wedged it in between a couple of parts and were moving the crank assembly back and forth. Is that what youre refering to after the oil pan is dropped?
Old 03-02-15, 10:55 AM
Ali SC3
Ali SC3's Avatar
yes, its the thrust washers that keep the crank from moving forward or backwards. once they wear out the crank is allowed to rock back and forth and eventually it will contact something metal it was not supposed to and something in the bottom end will let go. using a prybar on it is a simple way to access how much back and forth movement you have, if there is a noticeable amount its probably not good but if you replace the thrust washers you should be alright. check other things when they are in there bearings etc... that would be the time to change them.
Old 03-21-15, 06:24 PM
Ozzzzy
Ozzzzy's Avatar
Default Throwout
Well THERE'S your problem!
Yup, throwout - complete failure!
is3t
IS - 1st Gen (2001-2005)
02-15-13 06:32 AM
baodalazi
SC- 1st Gen (1992-2000)
03-21-11 10:54 AM
Biggu
08-30-08 07:57 AM
iameric
02-12-08 06:23 PM
Legends6spd
08-21-02 02:32 AM
Quick Reply: Clutch Drops RPM's?
