Hi have one ask (taillight module question)
I have a rear light with a crack in one corner and on contact with water that entered produced a short in my module taillights and I asked about taillights and a new module Part # 89373-24130but apparently they sent those of a sc300 1995 and mine car is a 1993 model and the module is part # 89373-24080 and my question is believed that these new lights work fine on my
car and do not pass the same as the new module and burn these taillight function well be possible that you can install any alluda will be well taken into account for my help in this problem
You can buy used tail lights fairly cheap.
If you could post a picture of the broken light it would help.
Is it the driver or passenger side tail light?
I am not sure that a 95 would work, and it would look different than the other side.
I might have a used one, or someone like aliga(gazi) on the forum probably would.
Hope this helps.
Alan
Hope this helps.
Alan
[IMG]https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x2000/80-image_95fc6c08efe4158448e900a7abfb6a236f4978e8.jpg[/IMG
Thanks Alan this module is diferent the my old module and the new tail light is the one sc300 year 1995 and when I put in the car this module is diferent but work fine in the old tail light only don't work the light in the spoiler
Today buy one same year and put and this don't have crack and work fine
the different years have different options. you will want to find one from the same year range as your car. 95 had different tail lights so try 92-94. 95-96 are prob similar, and 97+ are probably similar.
Thanks Ali sc3 today have time and put this new tail light this is the one sc300 year 1995 and my car is year 1993 this work fine only have blink in the signal light directions but is more better because the old tail light have one cracking in the cornel and all time my bulb is going out
