98 sc300 no brake lights, stuck in park.
ive got a 98 sc300, stuck in part without brake lights. i replaced the brake light switch and that didnt fix it. any ideas? no blown fuses that i can see.
When you state that you are stuck in park, I am assuming you have an automatic transmission.
As I recall, for that year, you must step on the brake to get an automatic transmission out of park.
If the brake lights don't work, and you can't get the transmission out of park while stepping on the brake pedal, I would check the brake light switch with new (not used) and try bypassing the switch.
Best of luck.
Best of luck.
