What oil to cool the radiator
Old 04-01-15, 02:59 PM
net4n6
net4n6's Avatar
Default What oil to cool the radiator
I have a 1997 SC400. The radiator has oil cooling reservoir at the bottom. What oil does it use and where to fill it up?
Thank you,
Net
Old 04-02-15, 04:56 PM
UZinator
UZinator's Avatar
Thank you,
Net
Do you mean integral transmission cooler?
Old 04-03-15, 01:12 AM
Kris9884
Kris9884's Avatar
The factory service manual shows using dexron II / ATF or equivalent trans/gear fluid.
Old 04-03-15, 04:46 AM
gerrb
Super Moderator
gerrb's Avatar
That will be your Auto Transmission Fluid being cooled. It flows from the tranny to that oil cooler via two hard lines if still stock. You check fluid level though the Tranny Fluid dipstick.
The best for me is use Toyota ATF Type IV transmission fluid for your Toyota/Lexus transmissions.
Lelouche
10-23-12 05:33 AM
gripau1
07-05-11 01:04 PM
eyeain
02-28-10 10:58 AM
Vitaliy23
05-08-07 07:29 PM
airahcaz
Performance
15
02-11-04 08:58 AM
Quick Reply: What oil to cool the radiator
