Crank Position Sensor
Old 04-02-15, 05:46 AM
Bankswood
Bankswood's Avatar
Default Crank Position Sensor
Can someone tell me the location of the CAR on a 93 SC400
Old 04-02-15, 07:48 AM
eknine9
eknine9's Avatar
It's inside the distributor. If you're getting a check engine code for the crank position sensor it means your distributor most likely has an internal oil leak and needs to be replaced. On later years the Crank Position Sensor is elsewhere, but I know the first few years it's in the distributor. Or at least on the SC300 it is, hopefully someone chimes in to confirm or correct this in relation to the sc400
devsc400
03-25-23 07:45 PM
JonnyO78
25
03-23-19 11:35 AM
Beermunder
12-18-17 10:34 PM
pubbin
IS - 1st Gen (2001-2005)
11-14-15 12:48 AM
RomanTPA
07-14-10 08:07 AM
Quick Reply: Crank Position Sensor
