seafoam my 92 sc300
Old 04-06-15 | 12:57 PM
unknown101's Avatar
unknown101
Default seafoam my 92 sc300
So I jus seafoam my sc300 yesterday. ..I put 1/3 to the gas tank..1/3 to where the oil goes in...and 1/3 thru the pvc hose..After that my car seems to run ****ty..I replaced the sparkplug and changed the oil....and it still run ****ty...The car only move a little at high rpm.....any suggestions? ??
Old 04-06-15 | 02:25 PM
ems's Avatar
ems
How much gas do you have in the tank?
Old 04-06-15 | 08:14 PM
oldManTan's Avatar
oldManTan
you're supposed to let it run and give it some gas while plumes of white smoke come out the exhaust, did you do that? and then change spark plugs afterwards once the car has completely stopped smoking.
Old 04-07-15 | 02:58 AM
TXMAG's Avatar
TXMAG
What oldManTan said. I've Seafoamed about 10 cars over the years and all of them ran a little/lot rough until it burned off. I usually take them out for a short drive (5-10 minutes) and make sure to mash the gas a few times until no more white smoke comes out.
Old 04-07-15 | 06:24 AM
unknown101's Avatar
unknown101
I have a little under half a tank..do I need to drain my old gas out?
Old 04-07-15 | 06:26 AM
unknown101's Avatar
unknown101
Yes I did that..but after the smoke stop..took it to drive for about 5-10 min...car started to slip like rev high...so I drove it home..and changed the sparkplug and oil the next morning
Old 04-07-15 | 08:48 AM
ems's Avatar
ems
You should be fine there.
And by slip do you mean clutch slip?
Old 04-07-15 | 11:34 AM
unknown101's Avatar
unknown101
No slip..I meant car doesn't seems to want to pick up..jus barely move a little bit at a high rev
Old 04-07-15 | 01:03 PM
unknown101's Avatar
unknown101
Any Other suggestion?
Old 04-08-15 | 08:52 AM
oldManTan's Avatar
oldManTan
just let it use up the gas, put the old plugs back in, the gas still has seafoam in it you don't want it to foul the new plugs already. it might be a good idea to change the oil again not the filter though. it's best to do this with a nearly empty tank.
Old 04-08-15 | 01:11 PM
unknown101's Avatar
unknown101
[QUOTE=oldManTan;8991367]just let it use up the gas, put the old plugs back in, the gas still has seafoam in it you don't want it to foul the new plugs already. it might be a good idea to change the oil again not the filter though. it's best to do this with a nearly empty
Thanks ill give it a shot
Old 04-08-15 | 09:44 PM
unknown101's Avatar
unknown101
I have been told that my clutch went out...not sure if that's the case..but when I put the car into first gear..The car doesn't dies.
Old 04-09-15 | 10:39 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
I had a carbon buildup problem, and I ran a bunch of seafoam through the booster line, got the smoke show, and still had the carbon problem.
I then used the oldschool method of squirting some water in the intake with the engine revved up and hot, and the resulting steam cleaned out the engine with no smokeshow just the actual carbon smoke making its way out (like 1/4 the smoke of seafoam) and in half the time I spent seafoaming it I had actually cleaned the inside of the combustion chambers some. (note I have a map sensor setup I did not spray down my maf with water).
there is always the chance of hydrolocking an engine when putting water into it, but after seeing the youtube videos of people basically pouring water into the engine and it still running, I gave it a try with a little squirt bottle, and It hardly made the engine even stumble and after a few minutes of letting it take some water in you can see the steamy carbony exhaust smoke coming out the exhaust.
anyways just thought I would share the old school steam clean method is what worked for me. I got tired of the sea foam smoke show and not getting any results. I am not responsible to what you do to your car so use any water at your own risk just like everyone else, but it can work and have good results when done right.
I am just glad I didn't have to pull the head to clean the piston tops for my carbon buildup on the piston problem.
If you have engine sludge from using DINO oil or going to long on change intervals, steam clean does not help with that, for that you do use the seafoam in the oil but be sure to change it as directed.
Old 04-09-15 | 11:19 PM
Kris9884's Avatar
Kris9884
^^ I had thought about that, sounds scary but, it's no different then meth/water injection. Have you seen the inside of the head at all since then? Any obvious cleaning?
Old 04-10-15 | 12:41 AM
oldManTan's Avatar
oldManTan
it's pretty crazy seeing people just stick a hose in their intakes lol, but i guess it works! also, if it's ever really really foggy, go for a spirited drive, that should help as well lol.
