How do I wire wideband o2 to Aristo ECU..i.e eliminate stock o2
Run wideband o2 off of Aristo ECU..
I currently have the stock o2 sensor (3 wire) feeding the Aristo ECU and wanted to eliminate it and use my wideband o2 (Which is being used as purely a monitoring device right now) to feed it...
How do I make this work?
I am looking for as specific and detailed information as possible
is it as simple as just cutting off old o2 and taking the wires to wideband?
Do you know the part # for stock JDM 3 wire o2 sensor
Does your wideband has a narrowband output?
If it does, then you would wire the narrowband output from your wideband into the wiring harness that connects to the ecu.
So it would go:
Wideband O2 sensor ----> Wideband computer----->Narrowband output wires ---->wiring harness--> ecu.
So it would go:
93MSB
Performance & Maintenance
07-14-11 10:10 AM
