2jzge FFIM write up?
Old 10-29-15, 11:21 AM
asianic68
asianic68's Avatar
http://www.ebay.com/itm/CNC-Machined...o70MBQ&vxp=mtr
this would be all i need correct @alisc3
Old 10-29-15, 12:32 PM
Ali SC3
Ali SC3's Avatar
these ones with the lip are better.
http://www.ebay.com/itm/1-4-NPT-Weld...o3zGUg&vxp=mtr
It's easier for your welder to weld and since they drop into the intake a little its cleaner and the sensors don't stick out as much. I drilled the holes on mine and those sit on the hole and then the welder welds them. the other kind they would have to hold or just stick on top its not as nice on an intake.
see how they aren't too tall on mine, it helps alot for the lines on the back for the brake boost if you put them there.
Old 10-30-15, 08:53 AM
joe diego
joe diego's Avatar
Question Ali...
Why did you go with a SC400 iacv and not your existing iacv?
Old 11-03-15, 05:23 PM
jshooter55
jshooter55's Avatar
ali i live in queens and wanna get this done can you tell me where you took your manifold to get welded
Old 11-04-15, 07:14 AM
Ali SC3
Ali SC3's Avatar
Originally Posted by joe diego
Question Ali...
The sc400, 2jzgte, 7mgte ones are self contained units which is why I had to get one of those. All have the same connector.
Our stock ones are split in half, the top half you can unbolt, the bottom half is part of the stock throttle body. Some people have recreated the bottom ha;f out of aluminum and welded that on and used the GE IACV, but no one sells that and In my experience its easier to get the 2jzgte weld on flange thats available and use a sc400 IACV which is inexpensive. the 2jzgte one is pretty expensive but both work the same.
I took it to a local aluminum welding/machine shop. most welding places do only steel so you have to look around/call around your area for someone who can do aluminum. It took me a little while to find a place but its worth it to know someone that can weld aluminum its not easy.
Old 11-07-15, 10:41 AM
jshooter55
jshooter55's Avatar
Ali do you know the part numbers for the power steering relocate i tried searching i know some one posted them in a thread but it doesn't seem to come up
Old 11-09-15, 04:54 AM
killersqrl
killersqrl's Avatar
Here ya go, I have it on my list of things to order soon.
90301-11016 Ring, O
44337-24020 Union
Old 11-09-15, 08:37 AM
jshooter55
jshooter55's Avatar
Thanx i thought you completed yours already
Old 03-12-16, 09:47 AM
joe diego
joe diego's Avatar
I plan on buying the RMR throttlebody, but I am not sure what rotation tps adapter I should purchase (ccw, cw or does it matter)?
Old 06-22-16, 08:42 PM
Studiogeek
Studiogeek's Avatar
I got this one:
RMR-107-ASSY-CCW+A
82.5mm Throttle Body - CCW Rotation Incl. TPS Adapter
I was told to get the Supra unit because it would be easier to sell if I ever wanted to. I am running a standalone now, that may be why this one was suggested for me.
Old 06-23-16, 04:22 AM
joe diego
joe diego's Avatar
Originally Posted by Studiogeek
I got this one:
RMR-107-ASSY-CCW+A
So the "supra unit" would bolt up to an SC300 lower runner?
Old 06-23-16, 08:10 AM
Ali SC3
Ali SC3's Avatar
hes talking about supra unit version of the throttle body, its the same throttle body it just turns a different way so you would need to use the supra tps and flip yuor tps wires.
Old 01-10-20, 03:23 PM
joe diego
joe diego's Avatar
Can someone please tell me how these parts go into the flange.
Flange to be welded on FFIM
Old 01-10-20, 03:38 PM
joe diego
joe diego's Avatar
Is this correct?
Old 01-13-20, 08:45 AM
Ali SC3
Ali SC3's Avatar
Looks right, the side your hand is on goes to the intake, the side with the black rubber washer goes to the iacv.
don't forget the 2 bolt gasket between IACV and the flange.
joe diego (01-13-20)
Quick Reply: 2jzge FFIM write up?
