Lexus SC400 92 Help OD light Blinking
Old 04-27-15, 11:59 AM
soccergk
soccergk's Avatar
Default Lexus SC400 92 Help OD light Blinking
Im having problems with my od light blinking when im driving. sometime it feels like it doesnt go in gear. also sometime turning the car on from cool start it has a ruff idle and hard to shift from park when it does it jerks and make a loud bang sound under the car. im pretty worried its getting worst and im 8 months pregnant i only have this car and dont want to part with it hoping to get it fix before the baby comes. any ideas whats wrong. its 92 sc 400 with 132000 miles. timing belt replaced at 112000miles new battery last month.
Old 04-27-15, 12:43 PM
irondonkey
irondonkey's Avatar
you could possibly need a new alternator.
Old 04-27-15, 02:11 PM
soccergk
soccergk's Avatar
the alternator checks out fine.
Old 04-27-15, 05:04 PM
gerrb
Super Moderator
gerrb's Avatar
have you check the transmission fluid level ?
Flashing O/D can be bad solenoid too.
Old 04-27-15, 05:34 PM
soccergk
soccergk's Avatar
Transmission fluid is fine it was the first thing i checked. how do you know if its a bad solenoid?
Old 04-27-15, 08:17 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Wouldn't hurt to check the ECU for leaking capacitors. The ECU is underneath the passengers side carpeting up by the firewall. Disconnect the battery, pull back the carpeting remove the plastic black box cover and then remove the ECU without breaking the harness. Crack it open and check for signs of leaking or corrosion. Any slight leakage is a red flag. Post up what you find! GL.
Old 04-27-15, 08:21 PM
MMCtuner
MMCtuner's Avatar
Flashing O/D means transmission failure.
Old 04-27-15, 08:22 PM
MMCtuner
MMCtuner's Avatar
8 months pregnant and you ask her to pull off the ECU just in case?
Old 04-27-15, 08:23 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
At 132k miles it is highly unlikely unless previous owners haven't touched the fluids.
dankneeton
RX - 1st Gen (1999-2003)
03-17-18 04:49 PM
BOBSOFI
12-09-08 03:12 PM
MeehSoFly
SC- 1st Gen (1992-2000)
12-02-06 07:44 AM
swollio
11-15-05 07:22 PM
Andymi
11-25-01 02:29 PM
Quick Reply: Lexus SC400 92 Help OD light Blinking
