ABS delete question.
just buy both sizes and return the ones you don't need. m10x1.5 and m10x1.25, although I still believe its 1.5. anyways, I guess you can but it just looks messier than with the abs there in the first place, lines going everywhere. that's why I did mine the right way and made new lines for the front and just made a new short one for the rear brakes. make sure you remove all your wheel speed sensors too as they are only used for the abs system, since you are not using it anymore I suggest removing the wheel speed sensors, computer which is right under the glove box and whatever fuses and relays power it so the light doesn't stay on on the dashboard.
Super Moderator
I wouldn't touch any of those sensors or wirings if I where you OP and if you are planning to boost you car. Exactly the same wiring will be used for traction control later for your aftermarket ECU. It saves you a lot of work and money. They don't do any harm anyway by leaving them now.
Instead of starting a new thread I thought I would try to get an answer here. I just deleted my ABS and now my EGR valve. I unbolted the canister located under the intake manifold. Does anyone know what to do this orange plug that was connected to the canister? Thanx in advance.
DRFT103
Suspension and Brakes
11-17-15 05:55 AM
bmsc300
19
06-22-13 02:51 PM
