Blower Motor Help
Hey guys, I'm helping a friend of mine with his SC400.
The car is a stock 92, but has an issue with the blower motor. It's been a really, really long time since I've worked on a SC, so I need a reminder.
The climate controls are different between years, (92-94), (95-96), and (97+). They plug in, but certain functions work, right?
Also this one I'm sure it's original because the climate control looks green, and beeps when I press the button.
The problem he's having is that the blower doesn't turn on at all. IIRC, if it's a bad power transistor, it should either be stuck at low or high correct?
The climate control works, but just nothing out of the blower motor. I took a look at the blower motor (which looks like a pain to take out), but I checked the pins for power, and it's got nothing. So I don't think the blower is bad, just something else failed.
Is there also a fuse for this somewhere?
TL
R
92 SC400
Blower motor doesn't work, climate control does.
TL
92 SC400
Is his wiring harness in the wheel well tucked? I bet there's a chewed up wire for the blower motor in there, if i remember correctly it's a blue wire with a red stripe on it. Just check all the wires in there if the harness was never tucked, that's the problem i had. I changed everything else i could change and nothing worked, it was simply a cut and corroded wire in the driver side wheel well.
BluesImage
05-12-14 10:40 AM
Geoff240ti
SC- 1st Gen (1992-2000)
07-06-07 01:55 PM
