common leaks in SC300's?
Old 03-26-03, 10:26 AM
mdfdsc300
mdfdsc300's Avatar
Default common leaks in SC300's?
Did a visual inspection of my '92 the other day. The area around the front of the tranny appears to be slightly wet. Upon closer inspection, it looks like engine oil NOT tranny fluid. There appears to be a very slight oil leak. Nothing significant enough to even show evidence on the floor underneath the car. It just seems to leak onto the tranny cover and gets burned off.
Is this common among older, higher mileage SC300's? Is it the head gasket or the valve cover gasket that is usually the problem?
TIA!
Old 03-26-03, 10:31 AM
quikturbo
quikturbo's Avatar
Probably just a valve cover gasket. Check the torque on the valve cover bolts first, if they are fine, pull the covers off to inspect.
Chris
Old 03-26-03, 10:37 AM
mdfdsc300
mdfdsc300's Avatar
Default valve cover de-installation
quik,
thanx for the quick reply...
What does it take to take the valve cover off? Do I need to take off the intake manifold and throttlebody assembly?
Old 03-26-03, 10:39 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
sounds like you need to find a good service manual to guide you through. as far as the leak goes, only one way to find out
Old 01-10-07, 06:29 PM
LSEGHATCH
LSEGHATCH's Avatar
Leaking near transmission? Could be rear main seal.
Old 01-10-07, 07:02 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
this is a 4 yr old thread, bub.
Old 01-14-07, 03:20 PM
philauldridge
philauldridge's Avatar
If you've got a leak near the front of the transmission, it is almost certainly the rear main seal.. best to live with it, unless it is pouring out substantially. Pretty rare for the cam cover gaskets to leak on these cars, but you could easily look along the upper back of the engine block to see if it is wet and oily also.
Old 01-14-07, 03:24 PM
Mortal300
Mortal300's Avatar
i had the same...its the rear main seal just as the guy described above...not a big deal...depends how much is leaking..mine is very little...shud be okay after a tune up...i need a new clutch so mine shud be fine after
Old 03-20-07, 07:55 PM
supra_trd
supra_trd's Avatar
Just called Lexus today quote: $918.37 for SC300 rear main seal repair
rscpa
RX - 4th Gen (2016-2022)
01-24-18 12:57 PM
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
nbeihl
GX - 1st Gen (2003-2009)
01-19-15 09:21 PM
Pheonix
12-18-08 11:41 AM
kino1161OL
GS - 1st Gen (1993-1997)
12
03-26-07 08:46 PM
Quick Reply: common leaks in SC300's?
