HELP! Overheating when in boost!
I've had my 1J in my car for at least 4 years if not more, no major problems
Doesn't overheat while driving or boosting on the freeway.
It has had electric fans from day one, never had a problem, even on a stock radiator. Then one day it started.
I did blow the upper hose, but i was using the same one that came on the engine. Lower was the stock sc one.
Now it has a larger radiator, the driftmotion oil cooler kit, a FMIC.
440 injectors, SAFC, Blitz Boost controller and upgraded 1j turbos @ 14 psi.
It does leak some coolant (whit smoke) or something into the exhaust when it gets hot
Thermo has been replaced. Heatercore bypassed. No cat
No BHG (no mixing oil/coolant), Exhaust gases in coolant test done..
Can't figure it out, unless the turbos are cracked...
Anyone have the same problem or ideas?
It's hard to say how often they fail. These 1J motors are 20+ years old, and that is one of the first things that people usually do when they do the swap is throw a new pump on. Yes, typically they do leak or squeal first, but to me it sounds like that may be the only thing left. If your thermo is new, radiator is new, and heater core bypassed, then the only thing really left to consider is the pump itself. And it is probably a good idea to change it anyway
I have a NAT sc300. My car runs on the warmer side, fresh coolant flush, new water pump, new oe lower hose. Little bit older upper hose. Tstat is a little older, that's next on my list along with silicone hoses.
I made a front vent or some say grill. But I mail did it for venting to the radiator. When cruising at 40mph my stock temp gauges has dropped one full 1/5th or a full notch on the cluster. Has shocked me and I'm so glad I did it. This pic is from when I just got done with it. I still need to do some more trimming, but my gf and I just had a little girl 2 days ago so work on the car is on hold for a couple weeks!
But I would say change the tstat, are you sure your gauge is reading correctly?
New coolant temp sensor and all new sheet metal ducting as well. Temp when idling or cruising is the notch below half (since there is no 1/2 way notch).. It won't even over heat when idiling and the fan's arent on. Only while drifting.
The only thing that hasn't been replaced was the water pump.
Would cracked turbos cause overheating? I know it could cause the white smoke..
if doesn't go away after this, i'll 1.5jz it with my h1c, although i'll miss winding it out to 7k
Custom sheet metal ductwork, replaces the OE plastic. Also a gt500 hood vent. No problems when driving normal, just drifting. Doesn't even seem to budge in temp when hard fwy pulls , etc. No oil temp gauge, but its a 8x11" oil cooler . it had the same problem before the cooler, I added it hoping it would cure the problem, but it didn't. Same with the hood vent. The turbos are custom built with the ebay 1jz stainless dp.
As i said, i used to tell people about ditching their electric setup in favor of stock, but i've never had a problem in 4 years, even while drifting at small and large tracks. I went to Irwindale in the summer, and even ran my A/C while waiting for my turn. I've never had a problem with these fans.
When I supercharged my SC400, I had a massive overheating problem.
I had a Koyo Supra Radiator, Water wetter, with distilled water, Ford Taurus electric fan (man that thing was a beast), and it still overheated, especially on the highway.
It ended up being my lower splash shield/under guard thing.
Put that back on, and it was good to go.
