Help needed! Auto body, manual ecu harness tranny swap
I put a 95 ecu harness and tranny from an oem 5speed donor into a 95 auto sc300.
Where can I find the two wires that need to be jumped??
Help please!
Help please!
No I don't have any extra plugs on my transmission. It's an original manual motor transmission harness and ecu. I tried biggu's wire from starter relay to the plug in the car but that didn't work either...
My plug was white but I tapped into the black wire with the white stripe like he said and got nothing...
Super Moderator
^^^ That is what I thought . It is not the clutch switch you need to bypass. You don't have that wiring since it was originally a car with auto transmission.
You had an auto car so the dash wiring / ignition is trying to check whether the Park / Neutral switch is in safety position but you don't anymore have that switch since your auto transmission is gone.
This is what you do ..
* Put a jumper wire between pin 6 of the IJ1 connector (gray plug ) and pin 23 of IK2 connector (white plug) . Go through the pages of the link below if you are not sure which plugs or pins I am talking about.
That should allow power to flow and crank / start your car .
IF you want to check the diagrams , it is on Post #83 of this thread
https://www.clublexus.com/forums/per...de-easy-6.html
A32Boost
Performance & Maintenance
24
11-02-12 10:40 AM
sniper
02-02-05 02:02 PM
