Odd engine swap possibilities for SC400???
If you do plan to shift gears and go with a JZ swap you have total chassis compatibility from Toyota. Based on the two examples you saw, I would recommend the 2JZ from the older GS300. Classic rule of thumb is that ALL 1992-1997 2JZ-GE bottom ends are just as overbuilt as Supra Turbo bottom ends, just with higher compression. Any VVT-i 2JZ-GE's made from 1998-2005 have equally strong blocks and cranks but will need beefier rods and pistons for turbo duty.
I think the GM 5300 V8 with a turbo is probably the best bang for the buck, assuming any LSx to SC mounting kits and conversion harnesses can be adapted easily.
the 5300 iron block with a turbo will net you the most bang for the buck power.
a 2jz on the other hand could deliver you more power, but it doesn't come on as early and is more pricey.
I was daydreaming about a Vortec 4800 today. Large bore with the shortest stroke made for a factory LS. Long piston dwell at TDC. Good head availability cuz 'Murican.
If the Vortec 5300 was a 2JZ, the Vortec 4800 is the higher revving, shorter stroke little brother 1JZ.
